scrambler info
Results 1 to 3 of 3
Thread: scrambler info
    Dec 2007
    123
    scrambler info
    year,engine hp (model sbh-223 serial 8365 bottom right of tag is 08403,tecumseh i think)under dash sticker says model 1200. are air scoops on fenders stock? they have 3" hose running back to motor.also are the rotors suposed to be glued together,after the clutch disengages it only pulls the first rotor disk into the pad
    Jan 2008
    Vicksburg, Michigan
    3,508
    Hey srg121,
    Wow a scrambler
    The hood scoops arent original that I have ever seen. The drive/brake rotor sounds normal. I did a search and did find this on your engine.
    Parts and Diagrams for Tecumseh SBH-SBH-223
    http://www.tecumsehpower.com/CustomerService/BSI.pdf
    http://www.cpdonline.com/692508.pdf
    Reading the last link sounds like it could of been a replacement short block? It is for 2 cycle engines but has Identiification tag info.
    I believe they came with a 7 or 8hp briggs
    10 or 16 tecumseh.
    I guess 12hp too but cant find it in any brochures.
    Good luck with it!!!
    Central NJ
    1,470
    Model 1200 is 12 hp. The engine is missing the cooling shroud and muffler. I have a complete 1200 Marc12 if you need any photos or reference.
