Ok you 2 strokers I gotta pick your brains a little bit here! what makes these machines either vapor lock or lose spark when they get hot or its hot outside?? I've had 2 machines do this and 1 is a cdi ignition.
Thanks
Dave
Thanks
Dave
My original 2 stroke would run great until it would warm up. My issue was bad rings.
Compression was good cold. Found the issue when we pulled the head and you could move the piston. Then came the first predator.
Dave, losing spark could be a symptom of a bad coil. Although I don't know your specific engine, CDI ignitions rely on coils to fire (an exciter coil at the flywheel and then a different coil to produce the spark.....I think). As the temp rises so does resistance, and resistance impacts the voltage output from the coils. If the output from the coil isn't just right it won't fire. Last year I had to replace the coil on my B&S 20 horse. It quit firing when it got hot. New coil fixed the problem.
G50Bs always had a really bad habit of losing fire to one cylinder when they got good and hot. I was told that the problem was that the stator plate warped with heat and one set of points wouldn't open far enough to fire correctly. I'm not sure that was the case but I know that a CDI would solve the problem. Does yours misfire or does it make the low, throaty whaaood whaaood sound? (Yeah, that's what I said.)
