Chain tightness
Results 1 to 5 of 5
Thread: Chain tightness
    Chain tightness
    Not sure what thread this should go in
    Searched and didn't find much on hustler chain tightness. The chain running to the front wheels on one side is sitting on the tub. whats the proper tightness for them, I am going to go with the same tightness as on the other side, but want to make sure I get them right.
    Jack the machine up so that side of the machine is in the air. Then push down on the chain tensioner by hand (after you loosen it of course) and then tighten the tensioner down thus bringing the chain off the bottom of the tub and snugging it up. There should be just a very little bit of up and down movement of the chain and it shouldn't be hitting on the bottom of the tub.
    Thanks, Ill give it a try in the morning
    Happy to help. Let us know how it works.
    Sep 2009
    In Michigan out annoying the neighbors in something that has a motor in it!
    484
    JP clear out your PM's, it's full.
    The trouble with retirement is.... I never get a day off !!!!
