when it rains it pours.
all of a sudden my Max IV started running rough. My neighbor said I had "Green gas " in it get it out. It was back firing and had no power. I drained the gas tank put fresh gas in it SAME thing. So i decide i need to clean the carb again. I did this a few months ago when it was surging and made it run great. So I clean the carb.. Take the jet out and clean it ect. Put it back together and dont realize i have dropped a bolt that has wedged between the flywheel. When i hit the key the starter turns a little then nothing. I take the rope crank cover off and there the bolt is wedged between the top of the flywheel. I get the bolt out try the key nothing. I try the rope it is cranking over but gas is pouring out of the carb, It back fires and actually catches top of carb on fire a little. This was all yesterday.
So o come home today decide to try some more. First i fear alost of gas in engine so i change the oil and filter. I then take carb back apart and clean. I then try to start with screw driver across solenoid. it trys to once but could never get it to turn over with the screw driver on the solenoid again. So I try to start with rope again. Gas is spewing out the carb and it trys to start and cathes on fire again.. Im at a lost i dont know where to go from here
