balloon/floatation tire valve stem replacement
Results 1 to 2 of 2
Thread: balloon/floatation tire valve stem replacement
    Aug 2007
    near olean, ny
    1,083
    Here's a long over due secret.. how to replace balloon tire valve stems..
    1) break off old stem.(thats the easy part..)
    2) get a package of the smaller valve stems(any auto parts store carries them ,usually.. # 413 's?)
    3) this may take practice.. you need a used pair of pliars, a dull screw driver, and some quality dish soap..(full strength..)
    4) slowly ..attempt to put the bottom end into the tiny hole of the wheel,after sand paper cleaning around the hole and wiping it off..
    5) a tiny bit at a time..making sure the stem is well lubricated with the dish soap.. Also holding the valve stem in the 5 o'clock position.(facing down,,)
    6) as you almost have it in all the way, turn the stem to the 6 o'clock position ,finish pressing it in..
    7) guess what? it is repaired..
    Happy AATVing!!
    any questions? feel free to ask..pictures forth coming..
    Sep 2007
    flin flon mb canada
    130
    i use the same tool the tire shops use with a little spray of wd40. the tool cost me 11.95 about 5 years ago. greggv
