Hello. I have a 2009 Argo avenger 8 x 8 with tracks. Now that the snow is gone, I would like to remove the tracks. The manual says to remove the axle extensions as well. Is this necessary? Seems like a lot of work every time I want to put the tracks on and off. It does not get heavy use, just putting around in the woods. Thanks.
Remove axle extensions?
you don’t have to remove axle extensions (otherwise known as wheel spacers). There are several versions (not sure which kind you have). They are all lug nut (or lug stud) related.
“Bearing extensions” on the other hand are the enclosed aluminum housings on front and rear axles that re-locate the outer bearing and flange further away from the body.
The most important piece of advice if leaving wheel spacers (axle extensions lol) “on” is to run less psi in tires and also drive slower, shock load less etc. After all, argos shine at low speed 7-8 mph or less. Leaving them on will add stability during off-camber maneuvers and also in the water. Hope that helps.
