Hi everyone,
Great website here, I have spent the better part of the day reading previous posts about the JLO engines while I was waiting for my account to be verified.. Great info!
I am new to this forum but not to 6x6. We own 2 original Max ATV's that we bought new in the 70s.. They have been neglected for some time, mainly because they still had the old style balloon tires that were in bad shape..
Recently I decided I wanted to get one of our max's going again, so I got a new set of wheels/tires (converted to 5 lug), rebuilt the tillotson carb, new gas tank, and some other bits..
I got everything installed, and I had the engine running for a little bit.. It fired right up on some carb cleaner, and ran itself on fuel for a while before I shut it off.. Now it seems to have no spark.. When I pull it with the recoil starter, it basically has no spark.. When I use the electric start it has spark but its very intermittent, and its not very strong.
I have been doing some reading on the forum, and it appears that like on any engine with points that they get dirty and need to be looked at. I have the recoil starter, the fan cover and all that stuff off, and I've hit a bottleneck at the flywheel like most people have.. I tried, against the better judgement of everyone on the forums, and tried to use a 3 bolt puller and partially stripped one of the threads for the recoil starter.. Fortunately i did not thread it in all the way so it should still be fine..
I am at a loss on how to best clean the points without taking the flywheel off.. Ive read a bit that not using a proper JLO type puller will usually end up damaging the flywheel, which I am not interested in doing..
The last time I had this machine running was maybe 2-3 years ago, and the engine ran OK..
I'd like to stick with the JLO engine if possible, they seem like decent little engines once they are well sorted, certainly at this point seems like it would be much easier to get all the external bits working than trying to convert to something else.. NOt to mention I'd like to learn more about the JLO's since i have 2nd identical max that I am looking at restoring down the road
