briggs oil filter
  • briggs oil filter
    anyone have the right no.s for a stp or fram oil filter for a briggs vanguard twin cylinder 21 h.p.motor . auto store can't seem to cross reference it with the briggs filter . thanks jboy
    I'm pretty sure this is what you need, https://www.fram.com/parts-search/PH...djzDTLH7bjAukA
      howling ...that's the same fram no. i found online . went to auto zone and advance auto and they had no fram filters starting with ph . looked like all the no.s had been changed . stp filter online for that motor says it's a stp4292 so i'll check that tomorrow . that filters
      howling ... that's the same fram no. i found online . neither auto zone or advance auto had any fram filters starting with ph . looked like they changed all the filter no.s . i found online that the stp4292 filter will work , so i'll check tomorrow . it's $ 14.......thanks , johnboy va.
        John. Have you tried Napa auto parts ?
          thanks 449 ...i'll stop by and check them out . j.b.
            no luck with stp or fram oil filters at any auto parts . got a briggs filter at lawnmower shop . jboy
              Napa 1348 or Wix 51348 from O'Reillys Autoparts, they are all I ever use.
                thanks jww ...i figured there must be some filters other than briggs . i'll write it down , ready for the next change . have fun , johnboy va
                  I ended up with a baldwin b7615 that was available locally
                    Awesome I have only had luck finding Briggs filters as well. Nice to have other options.
                    DanW
                      Using the wix number above I was able to find these from buggies gone wild, I guess use at your own risk, hope it helps, I know I'm gonna try a couple from this list
                      Manufacturer Part Number
                      AC PF1245
                      AC PF1787
                      AC PF53
                      BRIGGS 491056
                      CHAMPION LAB. PH2835
                      FRAM HP7
                      FRAM PH3614
                      FRAM PH6022
                      FRAM PH7575
                      FRAM PH9342
                      FRAM PH9566
                      KOHLER 5205002
                      KOHLER 5205002S
                      MOBIL1 M1102
                      MOBIL1 MO241
                      MOTORCRAFT FL793
                      MOTORCRAFT FL910
                      ONAN 1220645
                      PURO L10028
                      PURO L10241
                      WIX 51215
                      WIX 51348
                      WIX 51391
                      WIX 51785
                      WIX 57023
                      WIX 57181
                      Information on the Briggs Tall Filter
                      Briggs & Stratton Oil Filter 491056, 5909
                      larger image
                      $7.99
                      Replaces Kohler 52-050-02. For (14, 16, 18 and 20 hp) Magnum engines. Also fits B&S 491056. Fits all Vanguards and twin cylinder engines. 25.5 Micron.
                      (3.404" Height, 2.921" OD, Thread size 3/4 - 16)
                      Item: 5909
                      Description: FILTER OIL KOHLER
                      Replaces
                      BRIGGS & STRATTON 491056
                      CUB CADET 52-05025
                      CUB CADET 5205025
                      JOHN DEERE AM-101207
                      KOHLER 52-050-02
                      KOHLER 52-05025
                      KOHLER 5205025
                      PRIME LINE 18-7844
                      PRIME LINE 18-7884
                      PRIME LINE 7-07110
                      SILVER STREAK 83-010
                      SILVER STREAK 83-283
                      SILVER STREAK 83-284
                      STENS 120-345
                      STENS 120-970
                      SUNBELT B1FF180
                      SUNBELT B1OF280
                      DanW
                        BRIGGS-STRATTON 842921 - Alternative oil filters
                        Replacement oil filters for BRIGGS-STRATTON 842921:
                        Baldwin B7165
                        Beck/Arnley 041-0767
                        Beck/Arnley 041-8078
                        BIG A 92065
                        Bosch 0986452058
                        BRIGGS & STRATTON 120485
                        BRIGGS & STRATTON 492056
                        BRIGGS & STRATTON 492932
                        BRIGGS & STRATTON 492932S
                        BRIGGS & STRATTON 5049
                        BRIGGS & STRATTON 695396
                        BRIGGS & STRATTON 696854
                        BRIGGS & STRATTON 842921
                        CARQUEST 85065
                        ChampLab LF503
                        CROSLAND 2099
                        CUB CADET 120-5008
                        Donaldson P502024
                        Fram PH8170
                        HASTINGS LF503
                        HATZ 50302800
                        John Deere AM125424
                        John Deere AM125424C
                        John Deere AM131948
                        John Deere GY20577
                        KAWASAKI 49065-7007
                        LISTER-PETTER 751-12870
                        LUBER-FINER PH3656
                        NAPA 1056
                        NAPA 1056MP
                        NAPA 7035
                        Tecumseh 36563
                        Tecumseh 36961
                        Tecumseh 740057
                        Wix 51056
                        Wix 57035
                        DanW
