anyone recognize this engine in my terra tiger?
  • anyone recognize this engine in my terra tiger?
    i just bought this terra tiger and now i need to figure out what this engine is. i will most likely replace it if i cant get it to run but i would still like to know what it is. any help would be greatly appreciated
    ok so i answered my own question this morning when i took the engine out to try to clean the points up and get it running. it is a curtis wright kec-340. i cleaned the stator, points, and flywheel and get intermittent spark. does anyone know anything about these engines? a little help would be awesome
      CCW engines were very popular in the heyday of snowmobiles the 1970's. They were used in a lot of machines. I have a few 440s in my Raider snowmobiles(ok,12 of them at last count). John Deere also use them
      OOO-(
      Never argue with an idiot, they will drag you down to their level, then beat you to death with stupidity!
        Did you set the gap on the points?
        When you say intermittent spark ....is it both plugs or just 1 that has no spark.
          ok, so i re-checked my point gaps then cleaned the mounting bosses for the coils and then it fired right up on ether. now i need to sort out the tillotson carb. i may just take the mikuni off my 69 yamaha dirtbike for a tmporary solution. it has the correct mounting flange and everything
            Ditching a Tilliotson or Walboro carburetor for a Mikuni is the best possible move you could make. Those other carburetors are junk and they're extremely unreliable.
              Raiders were ahead of their time and really cool. We had a first gen 440 and second gen Eagle 440. The Eagle had maybe 12 miles when i sold it to a collector upstate.in the late 90's.
              Acta non verba
                so i have been tinkering with this thing a little bit and i have it running pretty good. the clutch seems to work when you rev it up and everything. now i just need to get a fuel pump and get this thing back in the machine and go for a test drive
                  Did you change the carb?
                  If you use the tillotson carb you dont need a fuel pump.
                  Replace the fuel line and filter and run the return line back to the tank.
                    im not going to waste any time on the tillotson carb right now. i used my 1969 yamaha carb to get it running and it works well so ill try to find something similar i have a few old jet skis and im going to use the fuel tank out of one of those in it. i think it eill fit fine. i havent looked too closely yet but i may find that they have a fuel pump in them somewhere
