Does anyone have instructions on how to tighten the drive belt on a 2000 Max2? Im srumped. Any help would be grratly appreciated
Max 2 drive belr
hey deb ....usually on most machines the motor mount has slotted holes that the motor bolts thru .just loosen the 4 motor mount bolts and slide engine back some to tighten belt . if the mount does have slotted holes and the engine is all the way back , then the belt is stretched enough that a new one will be needed . i think the slack in the belt is abount 1'' flex , but not 100% sure . look up '' tightening max 2 belt on the web ...should be some info . good luck , johnboy va.
deb ...just checking , could you see that the motor mount plate holes were'nt slotted or you just could not slide the engine back any further cause of the bumper . ? you may want to loosen motor mount bolts again and see if the motor slides forward . if not the holes are for sure not slotted . if it does move forward there are slots and your belt is stretched . i think my max 2 is a 2001 , engine mount is slotted and it has that bumper . sounds like either way a new belt is in order . jboy
