I have a 2005 max iv. I’m going to replace all bearing inner and outer. Are the inner bearings 62mm and the outer 72mm? Also are these flanges for the inner bearings? Thanks
Bearing flanges
Yes. So to do all bearing and flanges for a max iv I need 6 72mm bearings. 6 62mm bearing. 6 62mm flanges ( the ones with the cuts in them ) and 6 72 mm flanges. Correct? I’m going to take out the axle tomorrow and measure everything, but am just making sure
Yes that’s what I meant. Could I also put a non grease zerk 72mm flange on the inside of the frame where to bolts go through to hold the flange in the outside? I did that in my max ii because in the description it said it would make it stronger. Can I do that with the max iv? If you look in the pic below this is what it says for the max ii. Which I did for mine. Can I also do that on the iv?
