I took my machine out for it's first extensive test run since rebuild. It did great! The only problems I had was some leakage after swimming. I found the plastic headlight covers leaking water inside, but that's easy enough to fix. Today I put sealant between the locking collars/bearing & axle. The bearing flanges are sealed very well with rtv and I don't suspect a leak there.
One more little problem. I noticed my machine pulling a little harder on one side compared to the other. It's very noticeable during high speed cruise and quite annoying to have to be letting off constantly on the side that's pulling better. I will of course first make sure my tire pressures are all the same, but I think I remember this always being an issue in the past years. Any thoughts of why this could happen other than uneven tire pressures?
