My hustler has aluminum roll bar and plastic body 18 hp brigs runs and start great i bought new chain ajusters so chains are tight now i need the special bolts for the axels where are u guys buying these
I just bought me a hustler dont know much what im doing
Welcome to the site Wereonem. Congratulations on your purchase. McMaster-Carr carries the style bolt you need. It's called a shoulder bolt. https://www.mcmaster.com/fasteners
The best length will depend on whether or not your sprocket tubes have been modified. The bolt holes will wear and become elongated and sometimes it is repaired by welding a thick, cupped washer to the tube. If that is the case, the needed length becomes greater.
Without modification, the sprocket tube is 1-5/8 inch outside diameter. Thus, the shoulder of the bolt needs to be about 1-3/4. If yours have been modified you need to measure.
