Beyond a visual inspection for obvious holes and cracks, are there any tricks used to determine the water worthiness of a AATV?
Determining the water tightness of a 6x6
The only way I know of is to take the machine into the water. Before doing that, all of the outer bearings should be greased and drain plug(s) installed. Even then, you still might have a little leakage, but nothing significant. Worn bearings will leak more than new ones also.Borrowing tools is for the weak.
2000 Max IV, 25hp Kohler Command, 26" Titan Tru Power AT's
1996 Max IV, 18hp Briggs, 24" Serwas
1998 Max IV (project in waiting)
1995/1999 Max II, 16hp Briggs, 21" Rawhides
Hustler 950 (Project in waiting)
I forgot to add that if you do use the "take it for a swim" method, only go out for a short period of time. You could also remove the floor to see into the bottom to watch for signs of a leak. If you fill it up on land though, be sure to let it dry out thoroughly and re-lubricate the chain just in case. No matter what method you use, grease the bearings beforehand.Borrowing tools is for the weak.
