Chain Brand
  • Chain Brand
    Hi Everyone. I was wondering what brand chain you recommend for 6 wheelers. I have always tried to go with ones made in the USA or Japan as they seem to be of good quality, but looking for recommendations. I have a Attext ST 295. Also, wondering how much chain I will need. Does anyone know? It is #50 chain I think. Thank you!
    actually no chain is manufactured in u.s.a. only assembled . it's mostly all made in japan according to u.s. co.s specs. u.s.a. chain co. sells good quality and so does chains 4 less . each has good to best quality and prices. just don't buy the real cheap stuff . johnboy va.
      Thanks!
        Based on your response to this thread I'm assuming you've bought chains from one or both of the companies you suggested. If so, would you mind telling me which chains you purchased? Which series/grade/size ? I've purchased a chain last summer from Richard's Relics but I'd like to buy from somewhere else because it seemed awfully expensive for one fairly short chain. Thanks Cup
          This is the chain I ended up buying:
          Seems very well made (in Japan) and quite reasonable...
            I'll certainly check that out thanks!!
              yes cup...tsubaki is one of the best brands and very reasonable prices . good luck , johnboy va.
                The one pictured in the link that Budzinsk posted was a cotter pin style and didn't appear to have O-rings. Is that what you use?
                  Not sure why it shows a cotter key, but the master link is just a clip. It is not an O-Ring chain, as I believe O-Ring chains are too wide for many machines. I am sure there are a lot of people here that can confirm, but I think most use non-O-ring chains because of the width.
                    The info from 6x6parts pertaining to chains for Max machines states that when replacing chains you should stick with the same type of chain that you removed because different types require different size gears. Like you said the width comes into play. I don't know enough about chains to have a preference except that I'd like to find the strongest chain I can that will fit my application. I'll see if that company offers an O-ring version and if so I'll give em try. Thanks Cup
                      O-ring chain is NO stronger,but it will retain oil in the pins better than std chain.That being said oil wont get into the pins easily either.A good quality manufacturer will use good steel and you wont get excessive stretch or pin wear as some cheap no name stuff.There is a slight width difference in o-ring but most applications are not that tight of tolerance.
                        i ..like i'm sure other members , have tried o ring chain . i don't remember getting that much more life out of it than good quality regular chain. and i always wondered if the o rings keep dirt and water out of the pins , then how does chain lube get in there. you can also buy lube-free oil impregnated roller chain ( more money). in terms of type of chain needing different type gears .. i think that means # 50 chain won't fit on a # 60 sprocket as a example . maybe someone will correct me if i'm missing something. type of chain means the no. , not the brand i think . my max 2 uses # 60 chain and i have bought different brands..all fit ..just different quality . j.b.
                          Tsubaki chain is the best brand.
                            Originally posted by mfenmor View Post
                            I searched all over this site and the internet in general for a simple but informative explanation of the roller chains we use in our machines but I'll be damned if I could find it. How it didn't pop up on here when I searched I'll never know but it didn't. Most of what I found online was over the top super in depth mathematical/scientific analysis of chain designs, sizes, pitch, strengths, wear tendencies etc. and albeit kinda interesting and very educational, I didnt have the time lately to go that deep into it. Anyway, what you provided was exactly what I was looking for and I greatly appreciate it. Thanks Cup
