Trying to remove my front left axle to troubleshoot in/out play on the axle. There is also up/down movement so I'm think a bearing issue as well.
So I loosened the locking collar next to sprocket but I still can't get the axle to come out. Is there a set screw on the bearing that has to be loosened to let the axle to come out?
Space is very limited in this area and hard to get at. I've removed exhaust shroud and drive belt to make it easier.
Any tips would be appreciated.
Btw there is a keyway there as well
Thanks
Thanks
