mystery machine?
  • mystery machine?
    hello all newbie to 6x6s just picked it up but no clue what year or make any info would be helpful maybe where to get a repair manual cant find any serial #s any where,soon as i find out what it is i will post in the right thread thanks imagejpeg_2(2).jpgimagejpeg_2(3).jpgimagejpeg_2(1).jpg
    You have a very early Argo,the headlights are on the bottom half.You also have a serious chain sprocket alignment problem on the rear axles.I think this early of machine is also fiberglass.This is just off the top of my head,but members will add to this and you will know exactly what you have very soon. Eddie
      i thought the chains look crazy an yes it it made in fiberglass thanks for the reply.You also have a serious chain sprocket alignment problem on the rear axles.I think this early of machine is also fiberglass.. Eddie[/QUOTE]
        That's a 1967 Argo! So now we know of 4 beauties in existence. I can post some pictures of a restored one later.
        YouTube
          The driven clutch on the transmission looks EXACTLY like the one on the Attex 450 Tomahawks and Tomahawk 'Lil Trucks.
            it could be, this is the way i bought it first 6x6 i ever owned,dont know anything about it but im sure it wont take long as theres not much to it really
              does anyone know if the rear chains on this machine (pic 2) is supposed to be off set like this
                Definitely not. Roller chain does not like to do that. Perhaps the rear sprocket tubes(I'm assuming it has those) are just on backwards. Anyhow,the chain should be in a fairly straight line.
                Joe.
                  They should noy be that way, chain should be straight as joemeg wrote. The rear axles looks to be in too far making it out of line, the sprockets are welded onto the axles.
                  Loosen the lock collars on the rear axles and slide them out some, you may have to adjust them all by measuring off the frame to the idler shaft sprockets as a guide.
                  Are the center chains on an angle also?
                    got it apart thinking it was backwards but not the case axles are solid,and as said the sprocket is welded on,and i did try to line it up but didnt happen so ill just move the sprocket so its inline thanks for the replys
                      I have exact same machine its a 67 I can take pics of rear axles for you and serial number is on fire wall
