T20 Skid Steer Rebuild
  • Disassembly - Left Side
  • T20 Skid Steer Rebuild
    Remove the c-ring on the T20 input shaft. Jeff has a great picture of a tool that makes it easy to remove these in his T20 article. I just used two screwdrivers, one on each ear of the clip and hit them at the same time. Just be careful because this clip usually comes flying off.
    Remove the sun gear.
    Remove the washer with the ear on it.
    Remove the center housing plate.
    Again remove the band anchor rod and sleeve from the brake bands just like before. Then remove the carrier drum, sun gears, and needle bearings as one unit.
    Remove the washer with an ear.
    Remove the three thrust washers.
    Again make sure to reassemble everything upside down so that you don’t lose any parts.
      Posting comments is disabled.
    article_tags
    Latest Articles
    • Easy T-20 split shifter Guide
      by Rabbit929
      This is on a 94 Max II 18hp Briggs and Stratton You will need: Grinder Welder I got all my parts from tractor supply. Parts List: -1/2x1x2 inch steel bushing (anything will work but the inside diameter needs to be 1/2in) -1/2in steel pipe (hollow or solid, you only need about a foot) -shift knob of your choosing, I haven't found a matching one yet. -2 1/2in inside diameter spacers/washers (the think ones) Start by cutting the cross shaft. I cut mine an inch and a half from the ...
      10-31-2016, 05:36 PM
    • T-20 Assembly video
      by George
      This video walks you through the assembly of a Borg Warner Skid Steer T20 transmission.
      09-26-2012, 06:59 PM
    • Rework an Early T20 to Accept Thrust Washers
      by whipper-ag
      I'm sure that some of you have opened up some Early T-20's & found them FUBAR. Once the gears start digging into the drum face, it doesn't take long to ruin the bearings, wear the bands down & cause excessive wear on the ring gear. Fortunately, all is not lost. In most cases, it can be modified to add the fiber thrust washers which are now used in the Late Model T-20's. Here's a video how to do it.
      Whipper :6x6burnou t:...
      02-18-2012, 11:18 PM
    • Max II T20 Split Shift Modification Video
      by LarryW
      This is a how-to video for making a split shifter for your T20. While I did the modification on my Max II, the same principals will apply on most Borg Warner Skid Steer T20 transmissions regardless of which ATV it is in. Instead of having one lever that controls shifting of both sides this mod will let you shift each side of the transmission independently allowing you to counter rotate. I even got to scare myself a little.
      03-22-2010, 08:47 PM
      by Mike
      Borg Warner T20 Transmission Rebuild A large percentage of 6 wheelers utilized the Borg Warner / Skid Steer T20 transmission. While they are virtually indestructible when properly maintained many of these skid steer transmissions have been around for over 30 years. It is only natural that at some point in their life whether it is due to improper maintenance or old age, they will need new seals, bands, drums, o-rings, or bearings. This article will walk you through a tear-down and re...
      02-12-2010, 06:29 PM
    • Salsbury Clutch Rebuild
      by Don
      How-To rebuild your Salsbury Clutch Salsbury was a very popular brand of clutch system for many of the amphibious ATVs from the 1960s to around 1980 when they closed up shop. Attex, Hustler, Scrambler and Max used them on at least some of their models, and I'm sure more of the lesser known machines used Salsbury as well. Attex used model 910 for the ST400, Chief, Thunderchief and Superchief and the 780 for most of it's single cylinder two-strokes. I'll try and be clear on how to do a...
      02-11-2010, 11:36 PM
