T20 Skid Steer Rebuild
  • T20 Skid Steer Rebuild
    Borg Warner T20 Transmission Rebuild
    A large percentage of 6 wheelers utilized the Borg Warner / Skid Steer T20 transmission. While they are virtually indestructible when properly maintained many of these skid steer transmissions have been around for over 30 years. It is only natural that at some point in their life whether it is due to improper maintenance or old age, they will need new seals, bands, drums, o-rings, or bearings.
    This article will walk you through a tear-down and rebuild from start to finish of the T20 including the installation of a seal kit from Recreative Industries that includes new seals, thrust washers, and o-rings. It will also show how to install new bearings in the T20 while you are in there. All of the parts that you need to rebuild your T20 can be purchased directly from Recreative Industries. Give them a call 1-800-255-2511.
    Here is a picture of the seal kit. Not shown are the main housing gaskets that are also included and the two bearings which must be purchased separately.
    While this article is lengthy, the process (and transmission itself) is very simple. Not only is the rebuild rewarding it also allows you to view the inner workings of the transmission to better grasp how power is applied to the wheels. The T20 used in this article is from a late 90’s Max II. While there are several variations of the T20, the basic steps still apply.
    Before you begin if you would like to view the T20 manual you can find it in our literature section or just follow this link: T20 Skid Steer Manual. It has a factory recommended procedure for rebuilding the transmission if you would like to follow that instead.
    If you haven’t already, remove the transmission from the six wheeler and we will start from there. If you need help getting the T20 out of your 6x6, you can read the article on Removing the Skid Steer T20 right here in our How-To articles section.
    Let’s Begin:
    Drain the fluid from the T20
    If you haven’t already, remove the bolt that holds the clutch to the T20.
    Remove the clutch from the input shaft. This is a keyed shaft so you may have to use a screwdriver to pry it off.
    Pry the hair pin clips out of the brake levers (U channel).
    Remove the bolts and the washers that lock them into place.
    Now you can remove the brake levers.
    Remove the 9 hex head screws that hold the two housings together. These take a 1/4" allen wrench.
    Once the bolts are removed you can pull the two halves of the transmission apart. If it doesn’t immediately want to come apart, you may have to gently tap one side with a rubber mallet to get them to break loose. You really want to be careful when you pull them apart so that the drums, gears, etc. don’t fall out. In the following picture you can see that I made a mistake and the drum came out separate from the housing. Luckily the planet gears and carrier plate stayed on.
    Tip: If you set the T20 on its right side you can pull the left side straight up and not have to worry about losing any parts. The left side drums, gears, etc. will be held in place by the center housing plate.
    Now that the transmission is in two parts we will start working on the right side of the transmission without the center housing plate or input shaft.
      Posting comments is disabled.
    article_tags
    Latest Articles
    • Easy T-20 split shifter Guide
      by Rabbit929
      This is on a 94 Max II 18hp Briggs and Stratton You will need: Grinder Welder I got all my parts from tractor supply. Parts List: -1/2x1x2 inch steel bushing (anything will work but the inside diameter needs to be 1/2in) -1/2in steel pipe (hollow or solid, you only need about a foot) -shift knob of your choosing, I haven't found a matching one yet. -2 1/2in inside diameter spacers/washers (the think ones) Start by cutting the cross shaft. I cut mine an inch and a half from the ...
      10-31-2016, 05:36 PM
    • T-20 Assembly video
      by George
      This video walks you through the assembly of a Borg Warner Skid Steer T20 transmission.
      09-26-2012, 06:59 PM
    • Rework an Early T20 to Accept Thrust Washers
      by whipper-ag
      I'm sure that some of you have opened up some Early T-20's & found them FUBAR. Once the gears start digging into the drum face, it doesn't take long to ruin the bearings, wear the bands down & cause excessive wear on the ring gear. Fortunately, all is not lost. In most cases, it can be modified to add the fiber thrust washers which are now used in the Late Model T-20's. Here's a video how to do it.
      Whipper :6x6burnou t:...
      02-18-2012, 11:18 PM
    • Max II T20 Split Shift Modification Video
      by LarryW
      This is a how-to video for making a split shifter for your T20. While I did the modification on my Max II, the same principals will apply on most Borg Warner Skid Steer T20 transmissions regardless of which ATV it is in. Instead of having one lever that controls shifting of both sides this mod will let you shift each side of the transmission independently allowing you to counter rotate. I even got to scare myself a little.
      03-22-2010, 08:47 PM
      by Mike
      Borg Warner T20 Transmission Rebuild A large percentage of 6 wheelers utilized the Borg Warner / Skid Steer T20 transmission. While they are virtually indestructible when properly maintained many of these skid steer transmissions have been around for over 30 years. It is only natural that at some point in their life whether it is due to improper maintenance or old age, they will need new seals, bands, drums, o-rings, or bearings. This article will walk you through a tear-down and re...
      02-12-2010, 06:29 PM
    • Salsbury Clutch Rebuild
      by Don
      How-To rebuild your Salsbury Clutch Salsbury was a very popular brand of clutch system for many of the amphibious ATVs from the 1960s to around 1980 when they closed up shop. Attex, Hustler, Scrambler and Max used them on at least some of their models, and I'm sure more of the lesser known machines used Salsbury as well. Attex used model 910 for the ST400, Chief, Thunderchief and Superchief and the 780 for most of it's single cylinder two-strokes. I'll try and be clear on how to do a...
      02-11-2010, 11:36 PM
