my brother has an argo 2021 frotier 700. it pullsto one side allthe time. how to fix
argo steering problems
John is correct, that's the first thing to check. If tire air pressure is good, jack the machine up off the ground from the body with the tires above ground and check the chain adjusters, they can be adjusted either by placing your hand below and pulling up, or by pushing down from above. These techniques solve 99% of pulling problems.
