Trying to tune my carb using these instructions but I'm confused about a few things. At the beginning it references two different idle mixture screws, depending on which carb you have one is equipped with a RED screw and the other WHITE. It doesn't specify which carb comes with what screw and mine looks neither red or white. My carb is a Nikki part #808069 Then, a few steps later it says to "turn the valve" a certain way. What valve?!! Is there a screw or something that is also referred to as a valve? My guess would be what the instructions refer to as the air fuel mixing screw because it looks and I believe functions similar to a needle valve but I'm not certain on that. Could someone please shed some light on this for me. I've got snow to plow and this carb tune is keeping me from doing that. Thanks in advance...Cup
Factory B&S carb tuning instructions...confusing
If it is a 1bbl carb there is only one adjustment, that is the black capped needle on the flywheel side of the carb, 2 bbl will either have 2 needles on top or screws under a plate on top.
Some newer carbs are sealed but the needle may be under a plug.sigpic
It's a 1bbl carb with what Briggs calls an "idle mixture screw" located on the same side as the flywheel. They call the other screw the "idle speed adjustment screw" which is what sets the travel of the "throttle lever". As of right now the idle mixture screw seems to be doing nothing when I turn it in or out so I don't know what the problem is. What I do know is this situation is a pain in my a$$!! Thanks for the info...CupOriginally posted by ARGOJIM View PostIf it is a 1bbl carb there is only one adjustment, that is the black capped needle on the flywheel side of the carb, 2 bbl will either have 2 needles on top or screws under a plate on top.
is it not idling good or the engine just sputtering , missing , etc. i'm not a good motor man , but i know when my twin cylinder b and s vanguard would start running bad ...in most cases if i took the top of the carb off and unscrewed the main jet and blew it clean with carb cleaner , after that it ran great . a small piece of crud is all it takes sometimes . maybe this will help . jboy
You can't possibly know less about motors than I doOriginally posted by john swenson View Postis it not idling good or the engine just sputtering , missing , etc. i'm not a good motor man , but i know when my twin cylinder b and s vanguard would start running bad ...in most cases if i took the top of the carb off and unscrewed the main jet and blew it clean with carb cleaner , after that it ran great . a small piece of crud is all it takes sometimes . maybe this will help . jboy
. To answer your question...after some work I did to the heated throttle cable the idle was a hair high, excessive gas fumes and intermittent surging. Cable tension was a hair tight so I adjusted that which lowered the idle a little bit but not enough. Also have a longstanding after fire issue that needed to be addressed as well so I decided it was time to retune the carb which I've successfully done in the past but can't seem to now. The air fuel mixing screw doesn't seem to be doing anything when I turn it which isn't correct I know that. May have to rebuild it again or do it later and buy a new one for now. Thanks for the advice JB...Cup
Decided to order a new carb altogether because I just flat out didn't feel like messing with the one I have now any longer. Figured I could swap in a new one and rebuild the original one later when I had more motivation. Well...I ordered the wrong carb which wouldn't have happened if the accompanying info and pics were correct so I'm back to square one. To make matters worse finding a new/correct carb isn't as easy as I thought. Not one that's not ridiculously expensive anyway. I've found a few that are like for like to what I have now but they're $200 and up!! Seems like a year ago or something like that I could get the one I need for way less but maybe I'm wrong. Is there a company out there that has more reasonable prices on carbs and gaskets etc? If so please chime in. Thanks...Cup
