I’ve got a set of tracks made to go over my Good Year Rawhide III s. They are 25x12x9. The tires are cracked on the sidewalls. They don’t make these tires anymore. These tires actually measure 24”. I do not have room to go any taller, as you probably know most tires are not the actual size they are labeled.
So my question is does anyone know of another brand tire that actually measures 24” but is 12” wide for a 9” rim?
If I can’t find the right tire then maybe go to bead locks with a tube? Just a tube is not an option as it will rip off the valve stem when the tire slips on the rim. Ive been down that road before.
If I could even find a smaller tire that would work but most 22” tires have an 10” or 11” width.
