Ch740 command pro
I'm on the downhill side and reassembling everything but am having a small problem. My pistons are not marked for the flywheel side and I was too dumb to mark them upon removal as I took for granted there would be markings under the carbon buildup, well, there wasn't. The only identifying mark I can find is each piston has a nub or corner on one of the wrist pin journals. I'm hoping one if you guys can tell me if that nub faces flywheel or closure plate or doesn't it matter so long as they face the same direction. The assembly manual just says the head will be marked "fly>" mine however, are not. Thank you guys, I know it's just a small engine not rocket science but it's an expensive small engine and I want it right.
