I’ve been tossing around the idea of building a custom 6x6 with a high-clearance aluminum tub. I have a line on a mid-90’s MaxII that I was thinking of using for the guts, or at least the T-20 and something to follow for a frame and running gear.
I also have a line on some 2-ply low-impact tires out of Russia that I was thinking of using. They work out to about 35” in diameter and about 20” wide on 16” Rims. They make the same tires in 4-ply but that may have a bit too tuff a sidewall for a 6x6 with no suspension. I know a guy that runs tires from the same manufacturer in 51”x27”x21” wheels. Those are also in 2-ply rating and he has had no issues under a modified Jeep TJ. The 4 tires will float the TJ without the pan hitting the water.
I have means to make the tub and body out of aluminum. I was thinking a UHMW skid plate on the bottom. Space the tires on 36” centres with enough clearance on the tub to fit an Escargot style track under it down the road if needed. Those would also need to be custom built to match the profile of the tires.
I know a lot about Argos but very little about Max’s or the T-20 transmission. My biggest concern is if the T-20 could handle the torque of braking the 35” tires. I know it can handle a bit of horsepower but would it be a good option on something with big tires like this? Can parts in it be upgraded to handle the big tires or would it be the weak link?
Open to all trains of thought or suggestions as I’ve got time and want to spend as much of it as I need on the design stage. I’m a Machinist by trade so making the parts should not be an issue.
Thanks in advance for all your suggestions.
Posi
Posi
