Anyone ever run a Comment 44C ? It has 9 Ribs on the bell. Not a Bowl top like the stock unit. It says it works on engines up to 18 HP.
Just checking what's out there before I pull the trigger !
From what I know the 44C Magnum is a less beefy derivative of the 94c Duster clutch, the internals between the two look almost identical. The biggest difference is the HP rating of course, but also the size of the clutches, the 44C uses a tiny 7/8" top width belt, and has a 7-1/2" diameter secondary. Versus the standard 1-3/16" belt and 9-1/4" secondary that the Comet 94c and 700 series have. So if you wanted to run a 44C you'd have to swap your secondary to the matching 40D.
What is the outside diameter of the factory drive clutch ?
Still searching for one to fit my Kohler. I see them new but thy are Expensive ! And I want to make sure I get the rite one the First time.
