So....working on a 1988 Max IV. I have most of it torn apart, and am cleaning and refurbishing everything that I can.
This is what I've got:
Hollow axles that are quite rusted on the outside of the tub. I was hoping to get away with not having to buy new, but I'm not sure that will work out. The inner and outer bearing collars are stuck good, so I cut the first axle out so that I could dissect the bearings, etc to understand what I need.
My questions are:
1. Given the year, I thought the inners would be bushings, but they appear to be bearings. They are mounted in the same type of 4-hole flanges that the outside bearings are mounted in. Is this factory, or have these been refitted sometime in the past 27 years
2. Unfortunately, I think I will need to replace all 6 axles, but want to stick with non-splined so that I can reuse my sprockets and save some expense. Thoughts?
As usual, this is getting expensive
My questions are:
