Myself and hogneck were working with new rims. We cleaned the rims and the rawhidesand painted on black bead lock. I picked up a mini tier changer at harbour frieght. Anyways, we mounted three of the rawhides. Pumped up to10 p.s.I. let sit overnight. The next morning we put them on my Max. Stared to install tracks. The bead on the rear tier broke free. My question is, should the paint be removed from the bead. The black beadlock did not stick to the rim. Only to the tier.
tiers, beadlock
I just clean the tires and wheels then seat tire just to the headlock. I've used weldwood contact cement that is brushed on the wheel and tire,both sides, let cure for a couple minutes and seat to the rim. This worked well for me and hope it helps out.
Buggyman1 hit the nail on the head with his link using contact cement , HI-TACK gasket sealant. made by permatex. RTV is ok but does not glue the tire like this stuff will. Gotta be clean and clean again,tire and rim then set up in the heat for a good amount of time NAPA 4oz can brush on sticky goo.Originally posted by tattooman View PostMyself and hogneck were working with new rims. We cleaned the rims and the rawhidesand painted on black bead lock. I picked up a mini tier changer at harbour frieght. Anyways, we mounted three of the rawhides. Pumped up to10 p.s.I. let sit overnight. The next morning we put them on my Max. Stared to install tracks. The bead on the rear tier broke free. My question is, should the paint be removed from the bead. The black beadlock did not stick to the rim. Only to the tier.
I have an old set of Terras on wheels that I'm thinking of trying to reuse so this thread has my attention for sure. My question is, how permanent is the HI-TACK bead gluing method? My concern is that if the Terras don't work out and I would find a new tire to fit these 12" wheels, that I would want to be able to get the glue off.
Also with this thought, how permanent is the liquid latex glue that some guys use instead of Slime? I have an opportunity to have these wheels powder coated cheap but don't want to nasty em up too bad if I later want to get rid of the Terras.
Thanks1984 Hustler 980 and some other toys that won't even swim.
not that bad with Hi-tack. just a little harder to clean off the rim.Originally posted by cclingma View PostI have an old set of Terras on wheels that I'm thinking of trying to reuse so this thread has my attention for sure. My question is, how permanent is the HI-TACK bead gluing method? My concern is that if the Terras don't work out and I would find a new tire to fit these 12" wheels, that I would want to be able to get the glue off.
Thanks
