I have a t-20 in my 1973 attex and had pulled it out of my machine chained the fluid in it and put it back into my machine. After letting it sit while working on everything else on it trying to get my restoration on the machine completed, the tranny had leaked out nearly the entire quart of fluid it holds into the bottom of my hull over about a period of a month. It was leaking from the plungers and so I called RI and bought 2 new gaskets for the case and also bought 8 plunger o-rings which was suggested. After tearing into the tranny and having it all apart on the bench now ready to put back together i have noticed that there are only one o-ring per plunger in my transmission or 4 total for all 4 plungers. Is this common for older models of the t-20?
Also was glade I took on the task of doing this myself because I now know how simple the setup in these transmissions are and am pretty sure I could put this thing back together in my sleep.
 me off but but i advise you it will only get worse and it is to hard to detrmine how much  fluid you lost
						 thought
thought
