Two things that I didn't do when I rebuilt my Hustler 980 BIGFOOT was add to the reinforcement of the T-20 mounts/cradle (which I'm in the process of now) and rebuild the driven clutch on the T-20. Today my dad and I took it apart because it was in desperate need of a rebuild. Taking the back part of the driven clutch cam assembly off after removing the snap ring was a bear. I thought it would have slid right off as I gradually let up on the tension of the spring, but NO. It was on there so tight we had to use a 3 jaw puller and a hammer. There was a very deep ridge worn on the suface where the plastic sliders ride as the clutch opens up, and all three of those plastic sliders were worn down to practically nothing. I was wondering why after I ran my Hustler a while after the rebuild that it wouldn't really downshift and climb like it should. I'll be getting new plastic sliders, and a new back cast aluminum cam part of the clutch where those sliders ride (sorry I don't know the exact name of that since I'm not that good with clutching). Could this wear have caused my lack of proper downshifting and should I replace the clutch spring while I'm at it? Thanks for the help.
Notice the wear on the plastic sliders and the ridge worn in the cast aluminum cam part of the clutch assembly.
