I am looking for a set of Attex Thunderchief Sprockets. I need them for a racer, please let me know if you have some. Thanks.
Probably. I will be home next weekend...I think. It's been a lot of time on the road, but I will do my best to check on parts for you then.
If you have them I can drive up.
Bump!
Still looking for sprockets!
If you can give me the # of teeth and the spacing from the bolt hole to the sprocket, I will see what I have.
If countrybumpkin doesn't have what you need, member whipper-ag can probably get/make them for you. He's done several for me.
Thanks guys, I will have to go out tomorrow and measure the sprockets on my other machine because I don't have the correct ones to measure. I know the ones on my racer are 440 Thunderchief sprockets. That is what i am looking for. I will check them out and send the measurements in the morning. The sprockets are pretty much all that is left for my A stock racer. I didn't realize the sprockets that I had weren't going to work until recently.
I measured the sprockets and this is what I am getting. (Everything is in inches)
Standing in front of the machine.
Front Right 2-1/4
Middle Right 7/8 to the small sprocket and 2-3/4 to the bigger sprocket
Right Rear 1-3/4
Left Front 2-1/2
Middle Left ¾ to the small sprocket and ¾ to the bigger sprocket
Left Rear 3-3/16
The two middle sprockets are the most important, if I can find those I can make it work.
Small sprocket 20 teeth
Large sprocket 26 teeth
Thanks guys!
