Adair tracks or beaverdam argo tracks
Results 1 to 10 of 11
Thread: Adair tracks or beaverdam argo tracks
    What do you think about tracks for mud and snow for my 2018 argo outfitter. Anybody have any experience with beaverdam tracks. Please leave feed back
    5,055
    You will have to check with Adair on Outfitter availability, a few years back I had asked about the Centaur equipped with Adairs and there was a possible weight concern.
    I'm sure development may have progressed.
    Apr 2015
    NC
    169
    I have been very happy with the addair tracks. They go through mud really easily and it's nice to be able to take them in the water to swim.
    I am resurrecting this dead thread as opposed to starting a new one. I am curious about both these track systems and would love to hear additional feedback if anyone out there has any experience with either of the two...
    Specifically, how have either of them held up? Performance on the water?
    I'd be putting them on an old '95 Response 8X8.
    5,055
    Quote Originally Posted by Redhorse View Post
    I do not think the Beaver Dam tracks would fit on a Response without going to a smaller tire. Most people are happy with the Adairs.
    Oct 2010
    Wasilla, AK
    923
    not sure how much under-tire thickness Beaverdam grousers have, but they’re probably similar. As long as you have 22” tires, you’d be okay. Wheel spacer-wise, it depends on how high their belt height is in comparison to rear bearing extensions (if your machine has them). More than likely, you’ll need a larger-than-factory spacer because the beaverdam grouser is very square (or it always used to be) and has a wider contact patch. So unless the guides (and belt) are very low, then they’ll probably require oversized spacers. 10” wide tires vs 12” do offer additional clearance all things being equal, but grouser width on the inside and belt height will determine. ….unless they’ve tweaked it to be like other builders
    Feb 2017
    Central New Hampshire
    247
    I am running all steel Beaver Dam tracks with 25" tires. I have plenty of extra cleats, so if one breaks because I definitely climb over many loose rocks, then I just swap it out and keep going. I love the Beaver Dam tracks, but certainly both Beaver and Adair are very good tracks.
    Texas
    2,171
    Tracks are always going to be superior to just tires. It took me many years to accept the concept. I have Adair tracks and am happy with them. I've seen another Argo HDI with Beaver Dam tracks and it performed well too. I think that the selection is a customer preference situation like Ford vs. Chevy. In a pinch I would take either.
    Oct 2010
    Wasilla, AK
    923
    Quote Originally Posted by scimanstev View Post
    have you bent and/or broken any of your grousers? Also, what width wheel spacers are you using with your tracks and 25x12? tires?
    The original poster may have purchased new tracks by now?
    Feb 2017
    247
    Yes, bending isn't the problem. The trails I have access to have loose rocks. Some of them are about 100 pounds. The welds on the grousers can break, which can lead to bending. It's the oldest ones that break. It's not hard at all to swap one out. The tracks themselves can't come off unless an entire wheel comes off, which has definitely not happened, or the two 6 inch bolts holding the Kevlar together breaks, which has also never happened. The traction of these tracks is incredible. I have gone up a 60 degree heavily mudded incline with ease.
