My transmission will not stay in gear in reverse unless I apply pressure with my knee against the selector lever; also in low range it is fine at low speed but when I increase the speed to about 5 mph and when coasting at that speed the selector will move out of that position as well. High range is fine in all respects. I have greater noise from reverse and low range than high range. I am considering an overhaul of the transmission. What gears, bushings and bearings am I likely to have to address? I'd like to have these on hand when I dismantle the gear box rather than have long downtime from slow deliveries. Any help is greatly appreciated.
