I spent a numerous amount of time trying to figure out why my Hustler's chains was popping while turning. I recently, about two months ago, replaced the rightside chain tensioner coming off of the T-20, but the alignment was a few degrees off when i welded it to the chassis. Needless to say, after the chain popped a few, it was just a short matter of time when the chain would ride completely off of the idler sprocket. I was forced to saw and grind out the faultly chain adjuster. I'm thing of installing the chain adjusters that is found on the Max IV's center axle. This style is very simple, yet stout and greatly needed for the Hustler chassis. I've been thinking of pulling the chassis out all together and reinforce every 6-7 inches with 3/16 flat steel or 1 1/8 pipe. This will surely kill the flex I feel, however small it may be.
Now that I think of it, I feel like I've been working backwards. My engine and transmission is fully rebuilt with less than 6 hours on it, not to mention all of the add ons and here I am with chassis issues that is forcing me to break the machine back down to zero. At least now, I know that I have, and what improvements is needed to satisfy my expectations of how I vision my Hustler.
The bad thing is that I promised myself that the next time that I pull the chassis out that I would outfit the machine with at least 4 splined axles and sprockets. The good thing is that, I 'm getting deployed soon, so Uncle Sam will pay for the Apache Gear hardware . I guess I will see how everything goes. Its cool to have projects to do in the garage, but not when it leaves you with no ride for a while.
