hi/low gear
Results 1 to 9 of 9
Thread: hi/low gear
    hi/low gear
    what would you low gear for? pulling a heavy load or hauling a heavy load.
    Pittsburgh PA
    1,153
    In an Argo, the low gear is great for descending hills and driving tight trails. The machine is a lot more responsive in low gear. You also have engine braking in low gear.
    Northern BC
    2,990
    If you have a high geared trans, you will use low for almost everything :-)
    Jan 2013
    Sidney Ohio
    509
    I find it difficult to make turns in the woods and other tight quarters. Would low gear be better in those situations?
    Mar 2011
    Québec, Canada
    253
    Rarely I use high gear. Once in a while on a frozen lake when I have far to go. In woods always low gear. Anyway you can't go fast in woods. I also think that it is easier on the driven belt on low. I have an avenger 2004. Only changed 3 belts in 660 hrs and beleive me sometime I'm loaded heavy. 7 adults and some gears, a moose in thick woods. So for me always low gear. I think that the new ones with admiral trans it could be different.
    Jack
    Jack
    Apr 2011
    598
    Quote Originally Posted by Twizted1 View Post
    Low gear would def make a difference in these situtations....
    —Will Rogers
    May 2008
    Snowy Mountains, Australia
    119
    I thought low gear works best in the water too?
    Northern BC
    2,990
    My conquest is low geared, with a bigger 27hp engine, I use high gear most of the time. Low gear is used for launching Boats/Seadoo's, pulling other machines out, tight trails, thick mud, steep hills.
    My daughters conquest is Med Geared, it's run in Low Gear in almost any kind of mud or muck, tight trails, ect. It's run in high gear on dry/grassy rolling trails, mild hills.
    This machine will go almost as fast in Low Gear as mine will go in High Gear.
    Jan 2013
    Sidney Ohio
    509
    This may explain why I have difficulties turning in some situations. Thanks for the info. I will learn to run my machine right some day.
