I need help with my baker hill. so i adjusted my linkages to where the sticks dont hit the body anymore. but i can barely pull the sticks all the way back cause they almost hit me. i need help with this. Thanks
Have you adjusted the transmission pucks? There are adjustment studs on the back of the calipers. Loosen the 9/16 lock nut and turn the stud in with a 3/16 Allen wrench to the point where the play is out but the disc still turns when the stick is in the neutral (centered) position. If the pucks are in good enough shape, you'll be able to adjust the excessive movement out of the sticks.
Do i need to remove the transmission?
No, you should be able to adjust everything in place. If you have to replace the pucks, the transmission shaft will have to be removed.
i might just get new pucks. but i dont know where to get them, i already called richard and he said they are out and dont know if they are getting anymore in. so if anyone has some that would be great. or if you could tell me what material and thickness i need and ill buy it and make my own
That's a shame. The best results I've had were with the pucks that Richard Clark sells. I'll get you dimensions when I get home tonight, but you want a very hard brake material to make your own.
Okay thanks. and ill try to adjust those brakes. But yes please let me know thanks
I use the medium non metallic brake lining from Mcmaster Carr. 5/16" thick. 7x7 sheet i think. I use 1 1/2 hole saw and grind down to 1 3/8 or 5/16 diameter, can't remember which.
Mcmaster #3976K34
well i got my brakes adjusted ALOT better. now i gotta put a pin in some of the axle sprockets, because the axle is just turning in the sleeve and not locking up the wheels
Will a artic cat 340 engine work in my attex?
