Hustler outer bearings and flange
Results 1 to 7 of 7
Thread: Hustler outer bearings and flange
    Please see video posted below. My bearings seem way too loose in the flange. I realize it is not filled with grease and not tightened down yet. Is this normal, or do I have a mis-match?
    Thanks,
    Clay
    https://youtu.be/r_oEEghx6xY
    Feb 2016
    Mississippi
    1,108
    That's normal. When you tighten the flanges they will secure the bearing. Go to the parts store and get 6 o rings - that will fit the outer circumference of the bearing. It will help prevent water intrusion
    https://youtu.be/sjgzk3m-X_sI actually made gaskets for the inner and outer bearings. When placed inside the flanges, it actually made the bearing more loose than shown in the video. So much looser that I decided to not use them. Is this an error, or do the flanges need this gasket period? Sure is hard for me to use the gasket knowing it makes the bearings more loose inside.
    Feb 2016
    Mississippi
    1,108
    Don't put a gasket between the flanges. Instead use a light bead of silicone. But do put a gasket and silicone between the flange and tub.
    Feb 2016
    Mississippi
    1,108
    The inner bearing doesn't need any gaskets, orings or silicone.
    Thanks guys.
    Fairbanks AK
    1,459
    I use 3M strip calk between flange ant tub and loctite liquid gasket between flanges.
