Because the carb sits in the valley on the vanguards, they are VERY suseptable to moisture forming/collecting in the float bowl. The best thing to do is take the carb off and clean/rebuild it. I emphasize clean. You mentioned that the thing sat. Perfect scenario for "ICK" in the carb. Also; I don't know where you live, or where the argo came from, but if you have the reformulated gas by you, or it sat in the system, it may have deteriorated the insides of your fuel lines. The easiest way to tell is to disconnect a line and twist a screwdriver that fits snug in it. If you pull it out with light black/grey sediment on it, chances are the hose is breaking down and depositing in your carb. You'll have to replace them all. And last, the carb may just need the main jet adjusted. The jets have limiter caps, and sometimes they have to be removed to get the extra adjustment you need. (If you do a complete rebiuld and cleaning, the rebuild kit will have a replacement cap as you will have to break the old one to remove the needle screw for cleaning.) Hope this helps
It's all just nuts and bolts.
