1985 Argo S I/C 6x6
Results 1 to 7 of 7
Thread: 1985 Argo S I/C 6x6
    Dec 2018
    Muskoka, Ontario
    95
    1985 Argo S I/C 6x6
    All new chains, lights, fuel system, charging system, switches, brakes, drives like a new machine. in Muskoka. I haven't figured out how to upload pictures here.https://www.kijiji.ca/v-view-details...dId=1633702790
    5,055
    Quote Originally Posted by Facemelter View Post
    That version of the S was called the 6 Twin, if my memory is correct.
    If in fact it is a 85 my cousin bought one new and it was as Jim says a 6 twin and that Briggs although not my most favorite brand was one of the smoothest running engines i ever operated and the machine came in that brown color he had that machine for years never let him down.
    Dec 2018
    Muskoka, Ontario
    95
    Yea it is a 6 twin your right I wasn't sure
    Dec 2018
    Muskoka, Ontario
    95
    And the engine is nice . I also have an 8 i/c with the kohler 17hp opposed twin and its also a great engine. Nice smooth power. Something about those opposed twins.
    Having owned a early 80s 8 ic green motor and then a 88 8ic red motor both were stone reliable the only issues i had was with the red motor Kohler i did put a pile of hours on that one and early symptoms were backfire on startup mostly warm but not always shortly after it started doing that i lost ignition completely it turned out to be the ignition coil its like a lawnmower coil beside flywheel i left the machine at the cabin and when i returned on my next days off put a coil in all was good i assume overheat of the coil killed its life i used it a ton in the summer months other than that it was great a fabricated a alternator kit and did a remote mount oil filter helped with servicing.NCT
    Dec 2018
    Muskoka, Ontario
    95
    Yep all I've had to do with mine is a new ignition coil up on the intake, new condenser and clean the points. Dead simple to work on
