Parts wanted / Needed for hustler
Results 1 to 4 of 4
Thread: Parts wanted / Needed for hustler
    I got a new (to me) Hustler and need a few things.
    It has been upgraded to a 420 Preditor motor and runs well but is missing the linkage from the leavers to the t-20. have to rotate the things by hand to switch fwd/rev
    So I need linkage to t-20
    also I need rubber surround for headlights to keep the headlight in the body
    If you have any of this stuff spare I would like to aquire it some how
    Email me opelnut@frii.com
    Thanks these things are super hard to find parts for and 6x6Parts seems to not respond to email.
    Jun 2016
    Newville, PA 17241
    568
    Is yours the cable shift version? I'm looking for a shift cable for the right side for my wife's 960hk. For my bigfoot I fabbed alot of my own stuff, there doesn't seem to be alot of extra parts out there, axles and sprockets is mostly all I can find. I think hustler changed alot of designs or revised them in a short period of time, that is probably why parts are hard to find. My big foot is far from stock, everything has been modified so I can use readily available parts, I hate searching and waiting on parts.
    DanW
    Phoenix,Arizona
    178
    Richards 6x6 has lots of the hustler parts look him up . he has the headlight rings and body parts
    found headlight rings cheap on amazon, shift action is all rods n linkages. got a temp fix for now that works but will make it better as time permits
    want something like easy shift for max ( 1st hustler has but the holes in the diamond shapped shifter are smaller and super hard which prevented drilling out
