Attex 297 question
Results 1 to 9 of 9
Thread: Attex 297 question
    Dec 2012
    Youngstown, Ohio
    1,003
    Attex 297 question
    I am putting an old 297 together and the 21x11x8 Carlisle tires are too big. Does anyone know what tire I should use?
    5,055
    Where are they too big? Height or width?
    Dec 2012
    Youngstown, Ohio
    1,003
    Height. There is little to no clearance underneath.
    5,055
    Is the tire hitting the muffler?
    Larryw has them on his
    Aug 2012
    Shipshewana Indiana
    350
    You can heat the fenders up and bend them upwards for more clearance. Many people use 2x4 frames to hold up the body while cooling down.
    Dec 2012
    Youngstown, Ohio
    1,003
    You're right, he has all kind of clearance. It not only hits the muffler but also the muffler shield. It is sp tight you can't spin the tire. On mine I can't even fit my fingers between the top and the tread. I double checked the tire size and it is correct. Nothing has been modified on the. Machine.
    5,055
    His 208 has no external muffler, the first gens did have an issue with melting the rear tire if over inflated.
    Northern VA
    2,766
    I'd guess the frame has flexed to the extent that the tires rub. All the Attex are prone to it, but the first gen machine's light frame tended to be even more so. Have a look straight at the front and rear of the machine and see if it doesn't look like you have excessive negative camber.
    5,055
    Hey Don, was thinking the same thing. While there is support on the bottom of the rails, there is none on the top except trans at the rear.
