6x6 clutch question
Results 1 to 5 of 5
Thread: 6x6 clutch question
    6x6 clutch question
    bought a older 6x6 and I am putting in a Predator engine. The original motor mount has been modified by previous owner. Can any one tell me what the measurement is from center of transmission shaft to center of shaft on the engine. Need to know so I know what length belt to get.
    5,055
    You need to list what clutches you have to match the belt ie Salisbury, Comet, Invance etc., what the machine is, if known what engine etc...
    Argo recommendation is the 127-73 clutch from them to fit the Predator engine. Just need to know the distance between the two shafts so i can see if the belt they recommend will fit. Also that will help me to place the engine in the correct place for the belt they recommend seeing that the previous owner made a different mount.
    5,055
    Still need to know what the machine is/was, the Avenger, Frontier, most 90-early 2000's machine and earlier machines all had different belt/clutch configurations.
    Machine has to be 30-35 years old
