just got bruiser back out
Results 1 to 2 of 2
Thread: just got bruiser back out
    Sep 2008
    woodland pa
    537
    Just got out the 6x6 a week ago had issues with carb backfiring and would only run on choke.
    1st carb cleaning after setting 2 years yielded a headache of trying to pull fuel thru.
    2nd attempt i took every piece of the carb apart cleaned it ran wire brush bristle thru every hole. Had a very dry rubber gasket inside the float bowl. And the float bowl gasket really needed replaced.
    reassembled it with old gasket had to use gasket maker around carb and air intake old gasket to make whole Had no leaks still back fired and ran with choke good when high throttle with light backfire. played with it 2 days when rain was coming was going to garage it. It started fine and has ran perfect since
    When running crappy i found a carb that might fit but $600 dollars no way
    Found this will be here in 2 days
    https://www.ebay.com/itm/403694957928
    I hope i can turn the float bowl around backwards or i might have to modify a air cleaner
    Generac does not make a replacement carb for this or sell parts. I purchased a aftermarket carb for a 760gtv which is a dixie chopper mower engine
    My engine is 760cc 30hp generac engine
    2,665
    jeffery generac carb kit looks good ..it ought to do the trick after a bit of adjusting . 30 h.p. gives good power i bet . let us know how it turns out. jboy
