Hi friends,Just acquired a Vanguard 18 HP V-twin with Model #350447-1048-a1 and date code of 95012711.Engine idles and runs fine.I have adjusted both intake and exhaust valves to .005" 1/4" past TDC.But its kind of hard to turn over with pull start cord.I noticed that valve clearance is same .005" at the TDC and 1/4" past the TDC.So looks like its compression release is not working.Can it it be worn out cam or could be a jammed decompresser mechanism or tired spring on the decompresser mechanism?Just need suggestion you experienced guys.I checked the compression and its ~150 psi on both cylinders.Please suggest me.Thanks.
