Diamond shifter pins
Results 1 to 3 of 3
Thread: Diamond shifter pins
    Jun 2016
    Newville, PA 17241
    568
    Guys and gals who have replaced the pins in their diamond shifters, are you using heat and cold to install the new pins or do they just press in pretty easily? Are you using any kind of thread locker or anything like that? Should I use a hardened pin? If I were to just flip my pins around would that be acceptable? Maybe a dab of jbweld to fill in the flat spots? Has anyone had problems with the pins working themselves out after doing this? I'm trying to avoid buying diamond shifters again after learning the pins can be replaced. I have a set of diamond shifters with good pins but diamonds are bent/broken loose from the shifter where it's pressed together. Thank you for any input.
    DanW
    Feb 2016
    Mississippi
    1,108
    Go to the hardware store and get a 1/4 inch bearing roller. hopefully you can remove your old pin with a little heat. Clean the hole, add some loctite, and press the new pin in. You may need to grind it to shorten it to length.
    Or, if you have a good set of shifters but the diamond is loose, just weld them in place.
    Jun 2016
    Newville, PA 17241
    568
    Yep I saved the shifters from my max bc the pins are nice but the diamonds are loose/bent one is off. Thank you again. You're saving my butt big time on this build. Now if this rain stops I can get an early start.
    DanW
