Argo Beadlock compatibility
Results 1 to 7 of 7
Thread: Argo Beadlock compatibility
    Does anyone know if the 2017 Avenger huntmaster beadlock rims and tires will fit on my 2009 Argo Avenger?
    Thanks in advance
    yes nothing changed since 2006 when they introduced the 25inch rawhides
    Mar 2010
    innisfil,ontario
    1,431
    if you want to use the new beadlock rims on your 2009 then I do believe you will be in for an axle swap.
    Quote Originally Posted by pisces View Post
    Thanks in advance
    Oct 2010
    Wasilla, AK
    923
    Should be able to use them but you'll only get 1-1.25" additional clearance i(not 2.25-2.5")if mounted in the "out" direction, and very little clearance to the tub if mounted in the "in"direction. The full benefit of reversible rims is due to the fact that the extreme duty axles are also longer than stock. So some of your reversible benefits won't be possible, but you could still use the rims and have an excellent bead lock rim
    I was planning on using beadlock on the front axles with my chanel tracks.
    I have the 2.5" adair extensions and tuners on the center wheels
    Oct 2010
    Wasilla, AK
    923
    The aluminum bead lock wheels have something like 1 1/8 - 1 1/4" offset, so you'll only gain an effective wheel spacing effect of that amount, or you'll tuck back in your wheels that same amount when the wheel is flipped the other direction. The extreme duty axles are also longer by the same amount so that when added together you get the total 2.25-2.5" spacing you're after, or the extra axle length is erased when the wheel is flipped the other direction. You won't get the amount of wheel spacing you need unless you also swap to the extreme axles, the package was designed to work together. It would also mean new sprockets (different spline) anc different outer bearings (larger axle diameter). It becomes cost prohibitive very quickly. Best option is to order from the factory if you want it. Doesn't mean you can't do it you really want it.
    Buzz, thanks very much for the reply, are there any aftermarket options for beadlock?
