Detent springs
Results 1 to 10 of 10
Thread: Detent springs
    Jun 2016
    Newville, PA 17241
    568
    Detent springs
    I need to replace both detent springs and really don't want to spend the 30 bucks a piece from rr. I've been happy with everything I've bought from him so far but I'm really not into spending 60 bucks on 3 dollars worth of springs. I ordered a length of 3/16 spring on line but now I'm thinking I should've ordered 1/4" so the spring sticks past the groove a hair. What other solutions have you guys come up with besides spending that kind of coin on two dinky little springs?
    I measured the factory spring at 3/16 or 4mm, I'm just thinking now I should've ordered 1/4" instead so the spring sticks past the groove a bit so it holds it in gear better. Maybe I'm overthinking something small. I'm already over 400 bucks I to this transmission. After cleaning it all up everything looks good except those two springs. And it seems that the plates on the planetary gears were both backwards according to maxrules99 video on YouTube. These springs are all that's holding me from putting it back together. I'm hoping to o be riding before snow flies it's been a long rebuilding process with alot of setbacks along the way and other priorities getting in the way but I'm finally almost ready to enjoy this machine, not that the whole restoring rebuilding process wasn't fun and enjoyable, I'm just ready to actually get to run this thing since all the bugs will finally be worked out. Thanks in advance for any insight.
    DanW
    Nov 2009
    Michigan
    730
    Which trans?
    Feb 2016
    Mississippi
    1,108
    If you're working on a T20, and it sounds like you are, go with the factory size. There has to be room for the spring to nest itself in the shift collar as it slides from one position to the next. A larger diameter spring may not nest as it should, and thus won't shift.
    Jun 2016
    Newville, PA 17241
    568
    Yes sorry it is a t20. Okay now I don't feel like I messed up by ordering the a length the same diameter as what came out. The old springs are very brittle. It has the 9 tooth shifter gears if that gives any idea how old it is.
    DanW
    Nov 2009
    Michigan
    730
    I must be missing something. I dont know of any detent springs in a T20.
    Jun 2016
    Newville, PA 17241
    568
    They're in the shifter collars to help hold it in gear, mine kept jumping out of gear on the short test runs, and I could literally shift it forward to reverse with my pinky on the diamond, if everything was lined up. While I was replacing bands and seals I discovered the springs were broken on both sides.
    Edit** I could get it to stay in forward if I left my foot rest on the shifters, I did the split shift modification. But reverse if kept flopping out as soon as there was a little slack
    DanW
    Nov 2009
    Michigan
    730
    Oh that long one that is inside the shift collar. If you ask on here I'd be willing someone will have extras.
    Jun 2016
    Newville, PA 17241
    568
    Yeah probably about 3 3/4" inches+/-. I ordered a length of 3/16 stainless and a pack of various springs.
    DanW
    Fairbanks AK
    1,460
    I have a bunch of good garter springs. If you don’t get them correct it may not shift or stay in gear properly. Send me a text at +19073888582. I can put in an envelope.
    Feb 2020
    Southern IL
    5
    Did the springs that u ordered work? I’m in the same boat, need new detent springs but don’t wanna pay 60$. Do u remember where u got them at?
