Been scratching my head trying to fix a starter motor issue on my Conquest. When turning key to start it feels like the engine/starter has seized before bursting into life and starting. I noticed that voltmeter drops to zero when trying to start
Replaced battery with brand new plus tried a known good battery from my boat
Swapped starter motor from my other argo, which didn't have this issue
Cleaned all connections on power and earth leads.
Pulled sparkplugs from each cylinder
Ran additional cable direct from battery power and earth to starter motor
All of the above had no effect on this initial stall issue. Today up on the hill the argo started twice with no issue then the next 3 times it feels like a seizure
I had an issue a few months ago with the front cylinder dropping out due to push rod falling from a stuck inleft valve. Turning it over with plugs out rules out compression issues unless I now disconnect the push rods to see if that impacts on the issue.
Has anyone experianced this issue........Pretty sure it will be something simple..............just can't seem to see simple at the moment.
Thanks for taking the time to read this post
