clearing fuel line
Results 1 to 4 of 4
Thread: clearing fuel line
    clearing fuel line
    I've a 2016 Argo ECH749 and trying to clear the fuel line. I changed fuel filter n Fuel flows fine thru the mechanical pump. Any suggestions on how to easily clean/check the Hose from the pump since it disappears under the motor housing? thanks
    Following
    Disconnect at both ends and hit it with some compressed air? When in doubt, just replace it. Fuel line is cheap.
    Fairbanks AK
    1,460
    If your having fuel delivery problems I would check the drop tube in the tank. There was a small screen on some models that would get plugged and starve the engine for fuel. You need to drill out rivets in storage tray to access.
