Looking to trade 1998 polaris sportsman for hustler and or t20 or t20 parts. Parts or project machine.
Polaris needs battery, carb(or cleaned), and rear caliper. Not pretty but ran fine until fuel lines deteriorated and clogged carb. I may get around to cleaning or replacing it. Looking to trade for hustler parts machine or other t20 equipped parts machine or working t20. Can deliver for the right trade.
Polaris has angles welded above the radiator to fit a car battery. Cables can be switched and angles removed to use stock size battery in stock location. New rear axle new rear hub bearings new front struts new shifter new filter and oil and filter new fuel pump before gas lines deteriorated. Tires are okay but do leak after sitting awhile. Plastics are okay, not perfect but okay. Front rack is gone.
