Any recommendations on chain lube?
Results 1 to 8 of 8
Thread: Any recommendations on chain lube?
    Feb 2015
    Copper Country in the U.P. of Michigan
    57
    I have tried several chain lubes and some seem to just make a mess. Anyone have a go-to lube that I can try. Doing some maintenance and upgrades on my 1999 Max II, so you will see a few recent questions from me.
    2,667
    everyone seems to use something different . i use '' blaster chain and cable lube '' brand . i have bought high dollar stuff too , but did'nt seem to be any better . lube for dirt bikes that have the chains exposed to the elements is good also. you will get plenty of suggestions on here . jboy va.
    Mar 2010
    innisfil,ontario
    1,431
    castrol chain lube for me.
    Jun 2014
    North Eastern NC
    370
    I use dirt bike chain lube which doesn't fly off and make a mess, yet can be gleaned off with a pressure washer.
    Aug 2011
    Kotzebue, Alaska
    1,209
    We use a NAPA product. White lithium grease, in a spray can.
    It turns white as it's being sprayed on, letting me know where the grease is going. The 'white' eventually fades, leaving a coat of lithium on the chains.
    Might not be the best thing to use...but I use the same sort of white lithium grease spray to get into the gears/chain at the back that's hard to reach...and I slather/gob on red grease by hand on the chains when I have it jacked up and can spin the wheels. Some flings off/squishes aside...but no big deal. If clumps accumulate on the idler sprockets I just knock it off with a screwdriver now and then. Before the winter I grease it up really well (probably too much). I had to park it outside last winter and the cover/tarps I setup split and it filled with water/ice (basically filled up to just over the axels with ice). When it was eventually warm enough in the spring where I could chip the ice enough out to free up the drive train...the chains/gears/sprockets/etc...were all in great shape. I just regreased it again. That's the longest it's been sitting "wet" (~4 months).
    Pittsburgh, PA
    695
    We've been using Cyclo Red Grease. It doesn't seem to wash off easily.
    Jun 2020
    North Alberta
    61
    You could try Shell S2000 Red grease. It's says water resistant but I find it to be more waterproof. It stays put on my chain's and sprockets. Protects against Wear very well. Another I started using is Krazy grease. Used it on my dirt bikes and doesn't fly off. Washed them off and it's still there lubing the chain. I use it now on my bigfoot. Protects very well.
